Maikudou
I have 3 PS/2 FDDs, all different, 2 were working after cleaning and recapping, the 3rd one by Alps resisted my attempts and refused to work (there is a lot of oxidation on SMDs, it played completely dead). Luckily it had a separate small PCB with edge connector which connected to the drive via a thin ribbon cable, so it can be used as an organ donor. I have masterfully butchered soldered a 34pin + berg connector to use with one of my Nec drives and it works perfectly:
But here comes the question, I have noticed, TexElec's and ZZXIO's ones both have resistors, TexElec's even 3 different packs. Why? Does PS/2 sends too much current, or on the contrary, garden variety drives do that to poor unexpecting IBM? Why does one might need resistors on something which at least according to https://www.ardent-tool.com/floppy/Pinouts.html and https://en.wikipedia.org/wiki/Floppy_disk_drive_interface should be a simple passive interface switcher?
A separate question, more l like a curiosity, as it provides 12v too, can I use 5.25 drive, or will it be blasphemy?
