RadRacer203
Just curious if anyone repairs these. The one in my mosel 35 stopped reading disks and I have some similar issues with the ones in a PC Convertible
Bad caps.
Maybe try local-ish computer clubs and/or ham radio clubs.
Does the Maker Space organisation operate in the U.S.?
I use a piece of tape, cut in a small strip, to tack the chip down while soldering the ends. After soldered, I remove the strip. Use separate rosin flux so you don't have to depend on the solders flux. Also, use small diameter solder. If you don't have any small diameter, use your cutters to cut a small strip, length wise.
I'm 72 and can't see anything closer than a foot and a half without glasses, so I suspect anyone could do it.
Dwight
I repair them. Mostly it's bad caps. Sometimes the leakage damage is too extensive, I'm not sure what happens but the symptom is that the drive won't spin up. If your drive still spins up, it can probably be saved.
Actually, there's no real reason to assume that.The one in my model 35 worked perfectly until a month ago so I know that one can definitely be saved
When you say this, do you mean drives that load down the power supply or drives that only don't work. Most capacitor failures that I've seen are on the power rails. I've seen a few else where but not so many that I can count them.
Dwight
The caps are in both the power supply and signal sections. There's three nonpolar electrolytics in the motor control section. They don't drag the supply down when they fail, I suspect they just lose capacitance or the ESR gets really bad. On two of the drives that wouldn't spin up, I've pulled the motor control chip and found corrosion/goop under it, cleaning it up didn't fix the issue.
They're not spares if they don't work.The one that's kind of critical is the one in my model 35, the other 4 I have are just spares at the moment
