zombienerd
I've been working with Glitch over PM's for a few days trying to get the XT-IDE Rev 3 board working in my PS/2 Model 25-004.
I built the board, installed a Transcend 256mb DOM, loaded Bios 1.15, in compatibility mode (no chuck mod), but the damn thing refuses to boot on the PS/2.
It works flawlessly in my Packard Bell 300sx 386 machine, no matter what IO and ROM addresses I use, it has booted every time.
So far on the PS/2, I've tried 280h, 300h, and 320h for the first IDE parameter, as well as C8000, D0000, and D8000 ROM addresses. I've tried 308h, 380h, 400h, and 420h for the second IDE parameter.
On the PS/2, when I select the drive from the XT-IDE menu, it shows that it finds the boot sector, but then just sits on a blinking cursor. I've let it wait 5 minutes on each config test. CTRL+ALT+DEL does not respond, I have to use the power switch to restart.
I have no other expansion cards in the PS/2. Single floppy installed. No other HDD.
If anyone has a working config in their Model 25 or Model 30, I'd appreciate if you could pass along what settings worked for you. If you suspect there may be a hardware issue with my PS/2, please let me know where you think I should look...
I should note that my current floppy drive doesn't work properly, but I have a new one arriving in a few days. I haven't been able to see if I can access the disk by booting from floppy for this reason.
