Tsk, tsk, Chuck; dontcha know that if it's on a web site then it must be gospel? Surely you're not suggesting that some information found on the Internet is incorrect or misleading?Regardless of what the idiots at RG say, it's an async comms card. The large ICs are 16450s; the one pictured on the RG websidte has the 4-port daughterboard attached, giving a total of 8 serial ports.
Hmm I should learn to read upside down better I guess - looks like it![]()
Although the item in question is currently sold out, since they previously tested it (as a SCSI controller?) and found it to be working, it got to work both as a serial communication card and SCSI controller? Maybe if you tie multiple serial ports together, it can be used to hook up some SCSI drive?Recycledgoods said:This item is used and has been tested to be in good working condition.
Although the item in question is currently sold out, since they previously tested it (as a SCSI controller?) and found it to be working, it got to work both as a serial communication card and SCSI controller? Maybe if you tie multiple serial ports together, it can be used to hook up some SCSI drive?![]()
