Well, let me tell you a story. Back in the 1990s we won a contract to look after some city centre CCTV systems, and at the heart of those systems were a certain type of video multiplexer. These were all rack mounted in cabinets with glass doors, a recipe for disaster, surely enough, they started to fail a lot. The manufacturers wouldn't let us have replacement SMPSUs, they always insisted on having the whole thing back and taking ages to fix it, so there came a point where one went down, we had no spares at the time and the user desperately needed this unit to be working.
So we took it back to the workshop, took the SMPSU apart and noticed that some of the electrolytics looked visually suspect, so, as we kept a large stock of ordinary electrolytic capacitors, we recapped it, observing value, voltage and polarity of course, and to our delight it sprang to life. Took it back, installed it, customer happy. Until, that is, the same unit failed several months later.
This time we had a spare so we swapped that in and brought the original repaired unit back to the workshop and were mystified to find that most of our months-old capacitors were showing obvious signs of distress. Bulged, leaking.
At the time the now well known phenomenon of 'bad caps' wasn't really a thing so we thought an electrolytic was 'an electrolytic'. The fact is, though, that the capacitors used in SMPSUs are run at ripple frequencies up in the high KHz range and therefore have to be specified to work at those frequencies whereas 'ordinary' electrolytics are only expected to deal with mains ripple or audio frequencies.
If you use run of the mill electrolytics to re-cap an SMPSU it may work, but not for very long, and certainly not for anything like ten years of continuous operation.
