RizThomas
Hello again ,
I started on another thread where I asked about Using MSDOS instead of staying with the Compaq DOS3.31. I tried some of the suggestions but ended using a floppy boot disk for now. My boot disk includes attaching a Microsolutions BackPack so I am able to use my DOS Utilites/Program collections from CD.
Well, I found some other problems so far.
1. The keyboard cable are cracking badly.
- I solved this by replacing the cable and wired new 5pin DIN plug. I also cleaned the keyboard keys, contacts, etc so it is now OK. BTW, the cable is a coiled extender for AT keyboard.
2. Currently, the 20MB HDD does not write or read consistently so I tried to reformat it (Failed).
- I tried running Checkit on the HDD but once it reach track 321..it comes up with Error: Controller Failed.
- I also tried to low-level format it with SpeedStor 6 and it also failed (Controller failed) as well...seems consistent at around Track 321...
I haven't disassembled the whole PC yet so I don't have a visual inspection of the inside. My next move is to open and hope to see something that will be the 'fix'.
Does anyone have experienced this problem before? Thanks...
