natevw
My original Tandy 1000 has an extended memory plus wall clock ISA card, board model T512CLK-A1 by "A.T.D. INC Sunnyvale, CA". On it is a part labelled ATD-20 Clock/Calendar, 20 Year Battery.
Well it's been more than twenty years and the battery seems not to help it keep accurate time anymore.
I went to go swap out the battery, but on closer inspection it's actually a whole 28-pin chip/daughterboard. The bottom shows signs of the thing being potted; a hard and shiny black epoxy that gives off a "might not soften under heat" vibe.
Does anyone know what's inside of this part? Would it be relatively simple to swap it out for some underlying/compatible real time clock IC and wire in my own battery hookup?
The huge thread at http://www.vcfed.org/forum/showthre...d-for-the-Tandy-1000-line&p=551930#post551930 mentions this card model and then goes on to say:
Looks like that chip (sold by Tandy for other computers) was a DS1216E, which at least has 28 pins but was meant to stick between a ROM chip and various TRS-*) motherboard. Not sure if that would be a likely candidate on this IBM compatible style ISA board then :-/
I had to perform "surgery" on the Smartwatch chip on my HX when it's batteries finally died.
