Sabertooth
Thanks modem7. I got my type 3 going but my type 1 has got me stumped. Even using the Supersoft diagnostics I can't get any video so it's making it tougher to troubleshoot.
If you were to go to Intel, and ask them about their 8042 (or 8742) keyboard controller, they would say something like, "The 8042/8742 is not a keyboard controller. It is a multipurpose microcontroller. You, the designer/engineer, program it to perform the function you want; a controller in a microwave oven, a jellybean counter, a keyboard controller, etc."Well I haven't given up just yet. I am curious though, I did replace the keyboard controller U126 and I keep reading somewhere about programming this IC. I did not do this and was wondering if this IC is pre-programmed, as I have read from other sources, or do I have to do that?
Part, but not all. For example, if an unprogrammed 8042/8742 was put onto the 5170 motherboard, I cannot see how that would cause a timer error.Could that be part of my problem?
For the IBM 5170 motherboard, the 8042/8742 has been programmed with IBM code that makes the 8042/8742 function as a 'keyboard controller', one specifically suitable for a 5170 motherboard.
If someone goes to eBay, or wherever, and simply buy any 8042 (or 8742) they find, they could be buying an unprogrammed one, or a jellybean counter, or ...
I have just now experimented with a type 3 motherboard. I replaced the functional 'keyboard controller' with an unprogrammed 8742. The Supersoft/Landmark diagnostic ran error free up to the PROTECTED MODE CPU test, then it hung at that test (hung, because on a 5170 motherboard, a functional 'keyboard controller' is required to reset the CPU during that test).
The code for U126 is at [here].
Hello , can you make a video with post card to see all the codes that motherboard generate with IBM bios?
