Restoring Atari paddles
NeXT
Kamloops, BC, Canada
I have two sets of the Atari paddles for my 2600 but both suffer from twitching which I would assume is because they are worn out or dirty. I would tear them open and spray on a little contact cleaner or alcohol but would that cut it? Super Breakout is hard to play right now. :/
I used TV tuner cleaner on mine and they work a LOT better. Stay away from alcohol, they dry out parts quicker. The tuner goop has a lubricant in it to help them last longer. Kind of pricey per can at radio smack, but it lasts a long time. I have had the same can for over a year.
Well if I get a can of the stuff (and I doubt The Source will have a can now) I assume it will last forever. I'll go see what the local electrical hobby shop has.
Twitchy paddles are just nature's way of saying you're not playing enough. :)
there was a kit you could buy to repair these, I see it on Ebay. It takes some trial and error to restore an Atari paddle and then put it back together correctly.
