generic486
After much debate as to wether I should repair or replace, I have chosen the genuine but much harder path of repairing. Today I went out and got an allsort of electronic tidbits, mostly caps. I replaced electrolytic caps bar the 2 220uf 200v as none were in stock at the place of purchase. After the caps were replaced, I tested the power supply with one FH Tandon floppy drive from the 5150 but nothing occured. The PSU was still dead. However, I replaced the glass diodes (i replaced them with 1N4148's.) and gave it another tested. This time something different happened. After a few times testing and the PSU being dead, one time I did manage to get something different to happen. I had the floppy drive connected and the power supply turned on and plugged in and although nothing appeared to happen at first, after pulling the plug, the fan jolted a bit and a soft buzzing sounded and slowly faded. I have not been able to get this result again but it might be worth mention in case it reveals the failing component.
