glitch
Why not just drop in a new battery pack? They're cheap and available.
I did that a while ago after the replacement battery pack I put in died. The capacitors in the drive provide some retraction by themselves. Supercapacitor adds more though sloping discharge profile and ESR make them different than battery. They charge with resistor so it will be slow to charge supercap without change. -15 is used to charge caps so ypu probably need a clamp. Suspect I changed something to allow faster charge to reduce unprotected time. Battery will also prevent heads from loading onto platter with jolt to drive such as moving it. Capacitors likely will have discharged. If the battery pack has died on you it won't protect drive which is why I put in the caps since they should last longer. Some of my drives don't get powered on that often which batteries don't like.re: comments regarding the need to replace the RK05 head-retract battery pack. For this type of application does it need to be a battery pack? Could a 'supercap' be just as effective? Would the RK05 battery charging circuit need extensive mods to work with an appropriately sized supercapacitor?
Another option would be to run the drive on a UPS.
How about using an external non-rechargeable Lithium battery connected via a diode?
Um. I don't know how a modern "UPS" would handle a massive inductive load (motor, fan, and that head positioner"). I have an APC Matrix 3000 in my shed that needs fixing, it has a massive transformer in the bottom and would probably handle RK05's.Another option would be to run the drive on a UPS.
The Classic PDP-8 at the RICM also came from American Used Computer. It was donated by Deborah Monosson, the daughter of Sonny Monosson who founded American Used Computer. The DEC people used to call it American Abused Computer.Second, it was resold by American Used Computer out of Boston!
