Druid6900
I'd unsolder one end of that diode and test it again.
When testing a diode (or transistor junctions) you should have a low resistance in one direction and a high one in the other direction (as you foward and reverse bias the junction).
The same resistance in both directions in not normal and, if it is actually in parallel with a resistor, it should react about the same but with unusually high and low values.
