SB180 and COMM180 HD boot
dittman
Plano, TX
I have my SB180 with COMM180 working with my SCSI2SD now, but it won't boot from the HD. After reading through the documentation I'm not sure it's supposed to be able to boot from the HD like the SB180FX. Is that the case?
I'm not sure if this applies to the SB180 with COMM180, but the doc with the SB180FX states:
8. You may now operate your system in either of two disk contexts. If you prefer floppy disks as your regular working media, the system defaults to this mode. Known as the floppy context, the floppies remain drives A: through D: and the hard disk is accessed as drives E: through H:.
It is recommended that you run the program to change the disk context with the 'H' option aná operate under the hard disk context. The command 'CDC E' swaps drive assignments between the hard disk and the floppies. The floppies are now mapped to drives E: through H: and the hard disk is mapped to drives A: through D:. (The highest drive letter allowable is dependent on the number of floppies you have and the number of partitions you've defined.)
(I thought I replied but don't see it)
The drive letters can be swapped on the SB180 as well but I'd really like to have it boot from the hard drive.
