bhtooefr
I suspect I already know the answer to this, but I'm trying to install SCO Xenix 86 System V Release 2.1.3 (I know at least 2.2.1 exists, but the newest disk images I've found are 2.1.3) on my IBM 5155, which has a WD1002-27X controller and a Seagate ST-277R drive, and an existing DOS partition.
However, when fdisk tries to start, I get the following error:
I get this error whether the controller is in XT or AT mode.
Looking over documentation, it's looking to me like everything supported is MFM, and the XT FDPT doesn't actually support specifying the number of sectors per track. Is that a correct assumption? If so, I'll have to downgrade to a MFM controller to use this, I suspect...
Invalid Fixed Disk Parameter Table
cannot open /dev/rhd00
