Wow, this is a full setup, nice!. Sadly I can't use my PC-8031 with the PC-8001 as I don't have the PC-8033 interface. I've tried to find any replica of it but although it exists, no one seems to have published schematics of the PCB, just useless tiny pics. Seems to be simple, a single 8255 wired with 3 logic ICs...Jltursan, Many thanks !
My configuration :
You might have some luck on these two blog entries, although they are irritatingly incomplete:Wow, this is a full setup, nice!. Sadly I can't use my PC-8031 with the PC-8001 as I don't have the PC-8033 interface. I've tried to find any replica of it but although it exists, no one seems to have published schematics of the PCB, just useless tiny pics. Seems to be simple, a single 8255 wired with 3 logic ICs...
CONSOLE ,,,1
I started cloning the 8033 from the tiny pictures and scattered schematics last night, and I think I'm sort of halfway there. There were more than a few gaps in the provided info that needed a leap of faith or more research...
Next step is to fiddle with the floppy side connection so that I can support both the 36-pin PC-80s31 and the 34-pin edge connector PC-8031. My own 80s31 is sitting on the dock in Osaka, so it will be at least two months until it gets here to test, so no rapid testing is to be expected.
No worries, yep, I used the pictures from that article as one of the primary references on my own board. Thank you anyway. Still waiting for the drive to weave its way through the international mail system!Hi,
Sorry for late reply, have you seen this PC-8033 clone (view in Chrome or Edge):
PC-8033を自作する - ブログの練習
PC-8033というのは、PC-8001にフロッピーディスクユニットPC-8031を接続するためのインターフェース装置です。PC-8001本体は中古で結構流通しているので入手は容易(数千円程度)。PC-8031も数は少ないものの入手困難というほどではなく、ジャンクなら送料込み5000円ぐらいで買えます。ただジャンクなので動作保証は無く、私の場合は1台目は片方のFDDが不良。2台目はコントロールボードが不良。2つを組み合わせて動作品が1台できあがりました。PC-8001とPC-8031は揃ったのですがPC-8033が無いのでつなげることができません。ちなみに上記のPC-8031の動作確認は...blog.goo.ne.jp
Regards,
John
Let us know as soon as it arrives...No worries, yep, I used the pictures from that article as one of the primary references on my own board. Thank you anyway. Still waiting for the drive to weave its way through the international mail system!
