Sergey's XT Project - Home-made IBM PC compatible system
Hello Sergey, congratulations for your work, it's an awesome project,sorry to contact you here, is that I would like to know if you have pcb's for sale, Xi8088, SVGA card, Olp2 card, Fdd card.Backplane and Cf-lite. Thank you!
Hi,
I have all PCBs mentioned above. See http://n8vem-sbc.pbworks.com/w/page/35044530/PCB%20Inventory (Xi 8088 project near the bottom of the page) for current inventory.
Please PM me if you like to purchase them...
Hi,
Hi,
Can I buy everything I need from you to build one of these? I have a Vendex Headstart Plus case that could use a system inside it. I want an NEV V20HL in the worst way. (Why does it max out at 13MHz by the way? I thought that the best possible was 16 MHz?)
Chris
One question I have is: how compatible is this system with a real IBM PC?
I have been exploring democoding on 8088-4.77 with CGA, and found the following with CGADEMO: http://scalibq.wordpress.com/2014/11/22/cgademo-by-codeblasters/
Apparently my Philips is slightly slower at 4.77 MHz than a real IBM. The working theory is that the chipset has some extra buffers in order to make it run at 8 MHz (which would be async with some parts of the system, that have to remain at 4.77 MHz). This introduces some extra waitstates here and there.
We are looking at doing certain 'cycle-exact' effects, by reprogramming CGA registers on-the-fly, much like how special tricks on the VIC-II on C64 work for example.
I have found that some of these effects work on real IBM 5150, 5155 and 5160, but not on the Philips, because it is not EXACTLY the right speed. This will probably hold true for 99% of all clones out there.
Hi,
It is related to the way V20 and V20HL are clocked. 8088 uses 33% duty cycle clock, while V20HL needs 50% duty cycle to achieve the maximal frequency. Xi 8088 uses 33% duty cycle clock (as produced by 8284 clock generator), which limits the CPU frequency to about 12 MHz (13.33 MHz was the fastest I could get it running).
Also other things will limit the frequency: board does have wait state generator for I/O, but not for memory. So the controllers that have some memory (e.g. video RAM, BIOS extension ROM) need to be fast enough or have a wait state logic, and insert wait states themselves.
