daver2
10k Member
It is looking like there is definitely something wrong with this graphics RAM card doesn't there.
Can you just double check that it is plugged into the correct sockets the correct way around.
The 40 way cable should be plugged into connector CN5 with the little triangles aligned and the 10 way cable should be plugged into CN13.
Might also just be worth disconnecting the cables and reconnecting them again (one at a time of course) just to 'break' any bad connection that may have occurred over the last umpteen years...
