SIG/M usergroup disks
per
Western Norway
I recently got hold of the better part (if not all) of 75 or so volumes of CP/M files from "SIG/M, A USERS GROUP IN NEW JERSEY". Does anyone know if this has been archived somewhere already, or eventually have more info about this user-group?
Currently I am in the process of reading all of these disks at the moment, it's spread about in a collection of about 200 disks from various sources. Most of the UG files are on 8" double-density disks, so while there's 75 volumes, up to 4 volumes often share one disk (i.e. most of the disks in the collection is other stuff).
I had a look around, and I did find some of the same files of the disk I was looking at. However, it seems like the files I have are divided into other volume numbers than the one used there. For instance, the file I was looking at is in Vol 5 on that web archive, while it's in Vol 59 on the disks I have.
The SIGM archives used to be found here:
/cpmarchives/cpm/mirrors/oak.oakland.edu/pub/sigm​
I have a copy, here is an index of all 310 volumes:
I will go through and check when I have read everything..
There may be some differences, for instance it doesn't seem like the list you sent contain any commentary by someone calling themselves Zoso. A few of the disks I have has these.
Maybe what you have is 92 volumes of the CPMUG archive
I have a copy of these too
Attached is an index of these disks
A yes, that matches. It would also explain the discrepancy between these volume numbers and the SIG/M volume numbers.
After going through everything, I got vol 18 to 75 inclusive, except for vol 39 which seems to be missing from that box. I imagine there's two boxes with vol 1-17 and vol 76-92 that the owner of these disks either did not find or did not get.
I recall being sent a pile of the SIG/M disks for retrieval and telling the customer that they were already on the web. This was quite a few years ago; I'm a bit surprised that the question is still being asked. I think that the Walnut Creek CD collection even had them.
Those files were from a Tandberg CP/M Computer, which I had no cpmtools Definition.
This one worked.
# cpmtools
# TAN1  Tandberg Computer  256 bytes/sector - DSHD 8" - 256 x 26
diskdef tan1
  seclen 256
  tracks 154
  sectrk 26
  blocksize 2048
  maxdir 256
  skew 1
  offset 13312
#  boottrk 4
  boottrk 0
  os 2.2
end
# libdsk
[tan1]
description = TAN1  Tandberg Computer  256 bytes/sector - DSHD 8" - 256 x 26
#sides = extsurface
sides = alt
cylinders = 154
heads = 2
secsize = 256
sectors = 26
secbase = 1
datarate = ED
# Flashfloppy/GOTEK
[tan1]
cyls = 154
heads = 2
secs = 26
interleave = 1
bps = 256
id = 1
rpm = 360
#rpm = 300
rate = 500
mode = mfm
iam = no
$ cpmls -f tan1 -T raw,tan1 -D test1.img
     Name    Bytes   Recs  Attr     update             create
ACYDUCY .ASC     4K     18
ADE     .ASM    18K    136
APOLLO  .ASC     4K     21
BANNER  .ASC     4K     22
BIO     .ASC     4K     32
BLACKJAC.BAS     8K     64
BLKFRI3 .ASC    10K     75
BLKJK   .ASC     6K     45
CASUAL  .ASM    40K    313
CATALOG .18      2K      7
CATALOG .19      2K      8
CATALOG .20      2K      8
CATALOG .21      4K     19
CHASE   .ASC     4K     22
CHESS   .ASC    12K     94
CIVILW  .BAS     8K     64
COPY    .ASM     6K     46
CPM     .DOC    10K     66
DIAMONDS.ASC     2K      6
ENTE    .ASC     4K     26
ENTEP   .ASC     4K     28
FLTARITH.ASM    40K    308
FOOTBALL.BAS    10K     67
FPCONV  .ASM    18K    144
FURS    .ASC     6K     46
GOLF    .BAS     8K     49
GUNNER  .BAS     4K     17
HORSE   .ASC     6K     41
KING    .ASC     8K     57
LANDER  .ASC     4K     20
LINK    .ASM    22K    166
LINK73  .ASM    18K    134
LUNAR1  .BAS     8K     51
MANDALA .ASC     2K     14
MATH    .ASM    40K    310
MATH    .DOC     2K     10
MAZE    .ASC     4K     32
MILMON80.ASM    24K    191
PINUP   .PIC    10K     65
PINUP1  .PIC    18K    140
POKER   .BAS    10K     65
PROCSELF.ASM    46K    361
README  .DOC     2K      4
RM80    .ASM    60K    480
RM80    .DOC     8K     64
ROCKET  .ASC     4K     24
RUSSIAN .ASC     4K     18
SAP     .ASM     4K     30
SCOPY   .ASM     8K     60
SNOOPY  .ASC     4K     28
SNOOPY  .PIC     4K     31
STARTREK.BAS    28K    212
STMASTER.BAS    58K    455
STMASTER.DOC     2K      7
STRTRK/1.BAS    34K    261
STRTRK/2.ASC    22K    161
STRTRK/3.ASC    20K    160
TACOS   .ASC     2K      7
TAXMAN  .ASC     6K     34
TRADE   .ASC    16K    123
TRAP    .ASC     2K     11
TREAD   .ASM    16K    127
TREKINST.        8K     52
TSAVE   .ASM    10K     78
TWEETY  .PIC     8K     53
UGFORM  .        6K     33
VOLUME18.DOC     2K      7
VOLUME19.DOC     6K     41
W/SEARCH.ASC     4K     28
WARI    .ASC     4K     24
WUMP    .ASC     8K     49
XFER    .ASM    10K     68
ZOSO    .20     12K     90
ZOSO21  .DOC    20K    148
ZOSO21  .TOP    20K    154
   75 Files occupying    888K,     104K Free.
Larry
To be honest, I think web search-engines being smarter and smarter, to a point where actual relevant sites for ancient references such as SIG/M is being filtered out or miss-interpreted, has a lot to be blamed for here.
My bookmarks have these two links:
Found at the first above link is http://cpmarchives.classiccmp.org/cpm/Software/UserGroups/SIGM/_README.TXT which contains this:
This is *HUMONGOUS* CP/M's restored version of the SIG/M archives.
Founded in May 1975, the Amateur Computer Group of New Jersey (ACGNJ) is
dedicated to the amateur computer hobby. For many years its Special Interest
Group/Microprocessors (SIG/M) maintained a library of CP/M software
released on a series of disks.
The SIG/M software collection is still available today from several sources.
However, most of them are incomplete, and/or exhibit signs of accretion or
corruption (e.g., the Walnut Creek CD contains a SIG/M collection which
lacks several volumes, has additional files added to each volume, and whose
files no longer match the supplied CRC values).
This is the *HUMONGOUS* CP/M Archives' attempt to restore the SIG/M
collection to as nearly original condition as possible. In brief, the goal
is to precisely match the file lists and CRC values supplied in each
volume's -CATALOG listing.
This goal has, I believe, been almost entirely achieved, and is presented
here, in several formats: in expanded directories, and packaged as .ARK,
.LBR and IBM-3740 format .DSK images.
_SUPPORT
The _support subdirectory contains a number of files, most importantly
buildvol, the BASH shell script used to build this collection. You may use
this script to rebuild the collection yourself, if you're so inclined (read
the comments in that file for further information). But the most up-to-date
version can be obtained from Github at:
If you wish to rebuild the entire collection in one fell swoop, copy
_support/ to a writeable directory, download the ISO files (see notes in
buildvol), then just run _support/buildall.
Also included is -CATALOG.ALL which is a rebuilt-from-scratch version of the
individual -CATALOG listings offering a complete list of SIG/M contents.
This one worked.
# cpmtools
diskdef tan1
  seclen 256
  tracks 154
  sectrk 26
  blocksize 2048
  maxdir 256
  skew 1
  offset 13312
#  boottrk 4
  boottrk 0
  os 2.2
end
# libdsk
[tan1]
#sides = extsurface
sides = alt
cylinders = 154
heads = 2
secsize = 256
sectors = 26
secbase = 1
datarate = ED
# Flashfloppy/GOTEK
[tan1]
cyls = 154
heads = 2
secs = 26
interleave = 1
bps = 256
id = 1
rpm = 360
#rpm = 300
rate = 500
mode = mfm
iam = no
ACYDUCY .ASC     4K     18
ADE     .ASM    18K    136
APOLLO  .ASC     4K     21
BANNER  .ASC     4K     22
BIO     .ASC     4K     32
BLACKJAC.BAS     8K     64
BLKFRI3 .ASC    10K     75
BLKJK   .ASC     6K     45
CASUAL  .ASM    40K    313
CATALOG .18      2K      7
CATALOG .19      2K      8
CATALOG .20      2K      8
CATALOG .21      4K     19
CHASE   .ASC     4K     22
CHESS   .ASC    12K     94
CIVILW  .BAS     8K     64
COPY    .ASM     6K     46
CPM     .DOC    10K     66
DIAMONDS.ASC     2K      6
ENTE    .ASC     4K     26
ENTEP   .ASC     4K     28
FOOTBALL.BAS    10K     67
FPCONV  .ASM    18K    144
FURS    .ASC     6K     46
GOLF    .BAS     8K     49
GUNNER  .BAS     4K     17
HORSE   .ASC     6K     41
KING    .ASC     8K     57
LANDER  .ASC     4K     20
LINK    .ASM    22K    166
LINK73  .ASM    18K    134
LUNAR1  .BAS     8K     51
MANDALA .ASC     2K     14
MATH    .ASM    40K    310
MATH    .DOC     2K     10
MAZE    .ASC     4K     32
PINUP   .PIC    10K     65
PINUP1  .PIC    18K    140
POKER   .BAS    10K     65
README  .DOC     2K      4
RM80    .ASM    60K    480
RM80    .DOC     8K     64
ROCKET  .ASC     4K     24
RUSSIAN .ASC     4K     18
SAP     .ASM     4K     30
SCOPY   .ASM     8K     60
SNOOPY  .ASC     4K     28
SNOOPY  .PIC     4K     31
STMASTER.DOC     2K      7
TACOS   .ASC     2K      7
TAXMAN  .ASC     6K     34
TRADE   .ASC    16K    123
TRAP    .ASC     2K     11
TREAD   .ASM    16K    127
TREKINST.        8K     52
TSAVE   .ASM    10K     78
TWEETY  .PIC     8K     53
UGFORM  .        6K     33
VOLUME18.DOC     2K      7
VOLUME19.DOC     6K     41
W/SEARCH.ASC     4K     28
WARI    .ASC     4K     24
WUMP    .ASC     8K     49
XFER    .ASM    10K     68
ZOSO    .20     12K     90
ZOSO21  .DOC    20K    148
ZOSO21  .TOP    20K    154
Larry
I would like to propose a better definition:
# TANDSDD  Tandberg Data  256 bytes/sector - DSDD 8" - 256 x 26 MFM at 500Kbps
# NOTE: Track 0 Head 0 is SSSD 128 x 26 FM at 250Kbps, and the entire Track 0 remains unused
#       First half of Track 1 Head 0 is first system track data
#       First half of Track 1 Head 1 is second system track data
diskdef tandsdd
  seclen 256
  tracks 154
  sectrk 26
  blocksize 2048
  maxdir 256
  skew 1
  offset 9984
  boottrk 2
  os 2.2
end
This works with non-truncated images, and actually reflects where on the disk the boot tracks are located.
