thephysicist
Is it possible to put a memory board into the CPU cabinet or has all memory to be in a separate cabinet?
thanks
Michael
thanks
Michael
AFAIK the only Unibus-based CPU that could be said to have two of them was the 11/60; the intent there really was to put memory on one (along with the bootstrap loader) and all I/O on the other. In fact, though, there was just a single Unibus with the CPU located in the middle and both ends brought out to a series of Unibus slots and then terminators. The usual PDP-11 configuration puts the CPU at one end of the Unibus with the terminator there intrinsic to the CPU implementation.Paul correctly notes that with Unibus, you can put the memory "wherever you like" physically and it will "work" assuming you configure it correctly, with one major caveat. Read the manuals carefully! The caveat is that for "fast" semiconductor memory on the 11/45, there is a dedicated set of slots in the CPU cabinet on a "second" Unibus (called FASTBUS in the manuals). If you have core memory you can't use this second Unibus, and you aren't required to use it in any event. (I am not sure about the 11/70; I only have an 11/45.)
When I had my real 11/70, the MK11 memory box was in panel space 2 (counted from the top of a H960 cabinet).Is it possible to put a memory board into the CPU cabinet or has all memory to be in a separate cabinet?
thanks
Michael
