0000769e 53 push bx {var_4_1}
0000769f 51 push cx {var_6_1}
000076a0 1e push ds {var_8_1}
000076a1 56 push si {var_a_1}
000076a2 06 push es {var_c_1}
000076a3 57 push di {var_e_1}
000076a4 ba0000 mov dx, 0x0
000076a7 e8f7a7 call sub_1ea1 {Call to retrive drive 40 character drive id string}
000076aa 7306 jae 0x76b2
000076ac ba55aa mov dx, 0xaa55
000076af eb7b jmp 0x772c
000076b2 b92800 mov cx, 0x28 {set counter for the id string}
000076b5 26803d2d cmp byte [es:di], 0x2d {find the "-" in the string}
000076b9 7407 je 0x76c2
000076bb 47 inc di
000076bc e2f7 loop 0x76b5
000076be f8 clc
000076bf eb68 jmp 0x7729
000076c2 47 inc di
000076c3 26803d20 cmp byte [es:di], 0x20 {move past the " " to the first character of id}
000076c7 7505 jne 0x76ce
000076c9 47 inc di
000076ca e2f7 loop 0x76c3
000076cc eb5e jmp 0x772c
000076ce 8bdf mov bx, di
000076d0 ba0500 mov dx, 0x5
000076d3 8cc8 mov ax, cs
000076d5 8ed8 mov ds, ax
000076d7 be3cf6 mov si, 0xf63c {address of dive string}
000076da b90600 mov cx, 0x6 {"CP3022"} {lenght of string}
000076dd f3a6 rep cmpsb byte [si], [di] {0xf63c} {check string}
000076df 744b je 0x772c {jump if good or continue}
000076e1 ba0500 mov dx, 0x5
000076e4 8bfb mov di, bx
000076e6 be42f6 mov si, 0xf642
000076e9 b90600 mov cx, 0x6 {"CP3024"}
000076ec f3a6 rep cmpsb byte [si], [di] {0xf642}
000076ee 743c je 0x772c
000076f0 8bfb mov di, bx
000076f2 ba0600 mov dx, 0x6
000076f5 be54f6 mov si, 0xf654
000076f8 b90500 mov cx, 0x5 {"CP344"}
000076fb f3a6 rep cmpsb byte [si], [di] {0xf654}
000076fd 742d je 0x772c
000076ff ba0900 mov dx, 0x9
00007702 8bfb mov di, bx
00007704 be48f6 mov si, 0xf648
00007707 b90600 mov cx, 0x6 {"CP3044"}
0000770a f3a6 rep cmpsb byte [si], [di] {0xf648}
0000770c 741e je 0x772c
0000770e 8bfb mov di, bx
00007710 be4ef6 mov si, 0xf64e
00007713 b90600 mov cx, 0x6 {"CP3042"}
00007716 f3a6 rep cmpsb byte [si], [di] {0xf64e}
00007718 7412 je 0x772c
0000771a 8bfb mov di, bx
0000771c ba0700 mov dx, 0x7
0000771f be59f6 mov si, 0xf659
00007722 b90600 mov cx, 0x6 {"CP3104"}
00007725 f3a6 rep cmpsb byte [si], [di] {0xf659}
00007727 7403 je 0x772c
00007729 ba0000 mov dx, 0x0 {fail}
0000772c 1e push ds {var_10_1}
0000772d 50 push ax {var_12_1}
0000772e b84000 mov ax, 0x40
00007731 56 push si {var_14_1}
00007732 bec300 mov si, 0xc3
00007735 8bc2 mov ax, dx
00007737 ab stosw word [di]
00007738 5e pop si {var_14_1}
00007739 58 pop ax {var_12_1}
0000773a 1f pop ds {var_10_1}
0000773b 5f pop di {var_e_1}
0000773c 07 pop es {var_c_1}
0000773d 5e pop si {var_a_1}
0000773e 1f pop ds {var_8_1}
0000773f 59 pop cx {var_6_1}
00007740 5b pop bx {var_4_1}
00007741 e956ff jmp 0x769a
sub_7744:
00007744 1e push ds
00007745 2e8e1ed9c6 mov ds, word [cs:0xffffffffffffc6d9]
0000774a 8a16b200 mov dl, byte [0xb2]
0000774e 32e4 xor ah, ah
00007750 1f pop ds
00007751 c3 retn
00013c80 53 push bx
00013c81 52 push dx
00013c82 1e push ds
00013c83 56 push si
00013c84 06 push es
00013c85 57 push di
00013c86 ba0000 mov dx, 0x0
00013c89 e8836a call sub_1a70f {Get Drive Info}
00013c8c 724e jb 0x13cdc
00013c8e b92800 mov cx, 0x28
00013c91 26803d2d cmp byte [es:di], 0x2d {Find the "-"}
00013c95 7405 je 0x13c9c
00013c97 47 inc di
00013c98 e2f7 loop 0x13c91
00013c9a eb40 jmp 0x13cdc
00013c9c 47 inc di
00013c9d 26803d20 cmp byte [es:di], 0x20 {look for " " then move to first character}
00013ca1 7505 jne 0x13ca8
00013ca3 47 inc di
00013ca4 e2f7 loop 0x13c9d
00013ca6 eb34 jmp 0x13cdc
00013ca8 8bdf mov bx, di
00013caa 8cc8 mov ax, cs
00013cac 8ed8 mov ds, ax
00013cae ba0900 mov dx, 0x9
00013cb1 bea73b mov si, data_3ba7
00013cb4 b90600 mov cx, 0x6
00013cb7 f3a6 rep cmpsb byte [si], [di] {cp3044}
00013cb9 7421 je 0x13cdc
00013cbb 8bfb mov di, bx
00013cbd ba0c00 mov dx, 0xc
00013cc0 bead3b mov si, data_3bad
00013cc3 b90700 mov cx, 0x7
00013cc6 f3a6 rep cmpsb byte [si], [di] {cp30104}
00013cc8 7412 je 0x13cdc
00013cca 8bfb mov di, bx
00013ccc ba1100 mov dx, 0x11
00013ccf beb43b mov si, data_3bb4
00013cd2 b90700 mov cx, 0x7
00013cd5 f3a6 rep cmpsb byte [si], [di] {cp30064}
00013cd7 7403 je 0x13cdc
00013cd9 ba0000 mov dx, 0x0
00013cdc 5f pop di
00013cdd 07 pop es {var_a}
00013cde 5e pop si
00013cdf 1f pop ds {var_6}
00013ce0 8bca mov cx, dx
00013ce2 5a pop dx
00013ce3 5b pop bx
00013ce4 b444 mov ah, 0x44
00013ce6 8ac1 mov al, cl
00013ce8 e8b3f8 call sub_1359e
00013ceb 33c0 xor ax, ax
00013ced c3 retn {__return_addr}
You got a 1530 to boot from a CF card?!? That's my holy grail!
I have one with an intermittent Conner failure (more down than up...) that occasionally still boots. I'd love to do what you did.
Any chance you can share your patched BIOS? I have a 512MB CF card, so am I right in assuming it would use the same C/H/S values yours did?
Hey Kylball, taking a closer look at your photos I've not seen that particular ATA backplane. Would it be possible to see a picture of the front and back of it?
Hello,
I have a CF to IDE adapter I want to connect to my 1520. I guess it's not just a matter of plugging it in. How did you do it? Is there some kind of short cable to build to adapt the pinout of the 1520 to the IDE standard?
Thanks!
Yes, the 1520 has a similar backplane. By looking at the geometry of the connectors (two female 40 pins, one on the backplane and one on the CF/IDE card) I think a simple male to male connector would result in an inversion of the top and bottom rows of pins (ie pin 1 would be on pin 2, pin 2 on pin 1, and so on). So I figure I have to make a male/male cable that inverts top and bottom rows. Am I correct?
