geoffm3
Oh, and FWIW, when I first got the machine from the last guy, he had DOOM installed on it. Seemed to play fine then, with pretty much the same hardware (minus RAM, network card, and CD-ROM drive).
When you were checking this, was the mobo out of the case? PC speaker plugged in? sometimes that can give indication of a problem if there's no video too...
Hey, my old PC.
In case this hasn't been mentioned already, you should re-enable shadow ROM bios, and I would check the bus multipliers. I tinkered around in the BIOS a bit so things might not be optimal for gaming presently.
I love it! Despite the problems, she's a grand system. I wouldn't spend so much time and effort on it if I wasn't in love!
That's good. I am astonished that you're having so much trouble with games though! Granted mostly I used the machine to transfer stuff via FTP/SMB so that I could image floppies, so I never really used it much outside of those applications. I loved that case though, so stout!
I ran across these links here, which I believe are the jumper settings for that mobo, I don't see any way to jumper it for no cache:
http://motherboards.mbarron.net/models/486vlb3/vs486f.txt.html
http://motherboards.mbarron.net/models/486vlb3/vs486f.gif
Also, I am not for certain, but I might have run across a drive bay blank in my collection of pieces parts last night that may belong to this case. When I got it it didn't have a CD-ROM drive so only a 5.25" floppy was present in the big bays. No guarantees though, but I can send it on to you if you'd like to have it.
Nah, that's ok. I love the setup exactly as it is. Thanks for the offer though! I'm 99% sure that replacing the motherboard will end my woes (at least I freaking hope so!).
That's amazing that you used it with FTP. I gotta figure out how to do that one of these days.
A FTP client is included with TCP32 which also can be used on a plain Win3.1 box with Trumpet Winsock providing the tcp/ip stack. It works rather well.
I guess I'm just not sure how that all ties in with a modern PC. Not sure how to make the two communicate...but hey, I'm sure I'll figure it out!
I should probably just the thing working to begin with.
