I have a pcb tester built around a 286 with a ST251-1 in it. The ST wont spin up in the computer but it did spin up with another PS that i have. It might be the PS but when i measured the resistance between the 12V and gnd i only got about 30 ohms which seems kind of low. Does any know, or can anyone check what the resistance is between those two pins? If that is low is there a known fix for this problem?
Thank you
Russ
Thank you
Russ
