VirusVox
Hey all! I wasn't sure if this should go in the software support section or here, so apologies if it's in the wrong spot.
Today I acquired a complete copy of Star Trek: 25th Anniversary for Tandy & IBM Compatibles; the set is on 8 730KB 3.5" disks. Installation works just fine though disk 4, but when I insert disk 5 into my 386 the drive seems to become very active, and an after about 35 seconds or so an error flashes up (it disappears quicker than I can read, but I'm pretty sure it caught the words 'Data Error'). This problem also appeared once on disk 4, but it disappeared after a second attempt. This error has persisted through 4 or 5 different installation attempts. Any ideas on what might be causing this, and how I might fix it?
I can access the disk by itself through navigating to the A: drive and using a direct command, which does correctly show me the contents of the disk.
