S spiceminer Experienced Member Joined Mar 8, 2014 Messages 206 Location Europe Apr 14, 2024 #1 Dear all! A µPDP-11/23+ with RQDX1 controller reports at startup: In the list of bootable devices, I cannot see the RX50. Is there any possibility to boot from floppy disk or do I have a wrong boot ROM? Regards Stephan
daver2 10k Member Joined Jun 19, 2012 Messages 15,326 Location UK - Worcester Apr 14, 2024 #2 The RX50 is a DU device (if my memory is not defective). Dave
R Radix Experienced Member Joined Dec 7, 2022 Messages 313 Location Midlands, UK Apr 14, 2024 #3 It could be DU0, 1, 2, or 3 as well - you will know when you have one of the the two correct numbers as you will hear the drive when you try and access it... the lower number should be the top / left drive
S spiceminer Experienced Member Joined Mar 8, 2014 Messages 206 Location Europe Apr 14, 2024 #4 Thanks a lot! The ROM Revision 0.9 does not look like being the latest one, could this be the case?
daver2 10k Member Joined Jun 19, 2012 Messages 15,326 Location UK - Worcester Apr 14, 2024 #5 Err, have you tried booting from DU0, DU1, DU2 and DU3? Dave
S spiceminer Experienced Member Joined Mar 8, 2014 Messages 206 Location Europe Apr 14, 2024 #6 Its working! DU0 does the trick. Thanks a lot for your help!
daver2 10k Member Joined Jun 19, 2012 Messages 15,326 Location UK - Worcester Apr 14, 2024 #7 Simples! Dave
daver2 10k Member Joined Jun 19, 2012 Messages 15,326 Location UK - Worcester Apr 14, 2024 #8 Going to your other thread, XH0 is the DEQNA ethernet bootstrap. I assume the controller is missing? If you go into Map, you can change the default bootstrap device from XH0 to DU0 if you wish. Or you could try XH0 followed by DU0... Dave
