SunSpotter
So I recently picked up an IBM 5170 kind of on a whim since it was pretty cheap, and decided to open it up and see what was actually inside it.
I don't know much about its past life, but clearly someone didn't cheap out when they got it in '85. Its the 8mhz version with a full set of 640k conventional memory, with room for 2mb on the expansion card itself.
But what confused me is what I've only been able to identify as a 62 pin D-sub connector, which you can see here:
Pulling the card out, and doing some of my own research, I'm under the assumption that it was used to host a bunch of client side terminals. You can see the card in question here:
And the back:
But that's just an assumption, as I can't find anything definitive about this card. I'm mainly just basing my assumption on what Alloy Inc. (the manufacturer) seemed to specialize in. I'm also not sure what that 62 pin connector would have actually...connected to?
If anyone has any ideas, or maybe worked with this kind of hardware in the past, please share your wisdom.
And the back:
