I recently was given a Sun Sunfire v210 anbd Netra T1. On the back, for the terminal port, it has a RJ45 connection. So I have a RJ45 to 9 pin serial adapter on the way so I can access Terminal mode. On my older suns I needed a Null Modem cable to access Terminal Mode. Do I still need to use a Null modem cable as well? or can I hook the serial adapter right into the terminal?
Thanks
Thanks
