alan8086
Hi all,
Just a quick vid and rundown of where I'm at with my 12 year Superbrain quest:
A pick of the Mboard after all the socketing etc I've done:
I've socketed about 15 of the glue logic chips - partly to test them on my ABI Chip tester and partly just so I could see where traces go.
I replaced the PPI chip socket - previously when pressure was applied to that chip, it would cause distortion or a 'change' on the display. This was an intermittent connection where a trace met a through hole pad, now repaired and a new socket in place.
The CRTC chip socket has similarly been replaced, another bad contact beneath it. Z46 and Z48 were socketed so I could see where traces went and check continuity back to the CRTC chip.
The VDAC socket has been replaced - it was crusty with bits of IC pin stuck in one of its sockets.
The EPROM socket has been replaced - again, its been de socketed so many times, thought it deserverd a new turned pin socket.
The only non glue logic original sockets left are the 2 CPU sockets and the FDC socket.
The above is mainly for JonB who is kindly acting as my SB consultant!
Any other comments are welcome regarding a way forward. Personally I do think trying a replacement CRT8002-003 VDAC chip is worth a go. I have 5 of them, so it seemed unlikely that ALL of them have failed, but if I leave that socket bare, with no chip, the SB behaves in exactly the same way. Of course that may just mean there is an issue in the circuitry before the VDAC? Most of the IC removal/testing has been centred on ICs relating to the VDAC chip thus far.
Anyone have a CRT8002-003 chip for sale? The 003 bit is important and I've not seen that variant online so far.
Thanks,
Alan
Thanks,
Alan
