tingo
Neat clock! It is inspiring to see new projects with vintage hardware. Thanks for sharing.
Please count me in for a PCB, I have a spare RQDX3 that I can borrow the chip from.
I started working on the schematic last night.
I found that I have several extra MC6850BJCS UART chips - ceramic, gold leads, gold lid, 1978 date code. I will "share" when the PCBs are ready, so nobody (probably) needs to buy any, unless we have a lot of customers.
I can't find (yet) a reference that says what the "BJCS" variant is. So I would assume that they are 1 Mhz. The faster parts are normally marked "68A50" or "68B50". The package matches the "L suffix" in the datasheet. I'll plug them into my "development system" to be sure that they work.
Pete
Any opinions on what the baud rate should be? Does it need to be settable? I'm hoping to keep things simple.
Pete,
That is quite clever and I hope you can fit this feature onto the board. I always wished there was an easy way to save programs entered into the DCT-11EM (but there isn't).
Lou
+1. Do you have a DCT-11EM Lou? Anyone seen any circuit-level documentation (not just the block-level diagram in the user's guide)?
The approximate bare-board cost looks like it will be about $25 for one, $46 for two, $67 for three (shipped, from me).
That's for a quantity of 8 total.
Qty 10 would be $23, qty 6 would be $28.
Pete
This is a huge timesaver over wire wrapping.
Thanks guys. Just for "full disclosure", the price estimate doesn't include any profit for me. I took the delivered price of ExpressPCB, and added $4 per package to ship to you.
My motivation is just to reduce the cost to myself for 2 or 3 boards. I'm not sure what I'll actually do with the boards...
Based on the current board size, the cost delivered to me is:
6 boards for $143.
8 boards for $165.
The layout routing is proving to be a bit challenging at the current size, so the size may have to increase just a bit.
Or, eliminating the headers for address/data/control bus signals would help - let me know if we want to back off of that requirement.
A space-saving alternative for the CPU bus signals is to not include a header, but instead simply include a via on each signal that is accessible from the bottom side. Then it would be "possible" to solder individual wires to each signal (but certainly inconvenient).
Another (better) idea: Instead of the 2-row IDC-type headers on the edge of the board that I have now, how about a single row of twenty 0.1" pins on each side of the T11, and similar next to other chips that need signal access? The routing should be much easier I think. It would still be possible to buy or make a 20-pin ribbon-type cable if necessary, or mount a hand-wired perf-board above or below (if the SIP rows are populated with long WW posts).
Would that be OK with everyone?
Pete
I checked on the pricing formula: The size-related part of the pricing is simply 70 cents per square inch per board. The other costs are roughly fixed (setup fee of $61, shipping, a small charge for having lots of holes, etc.). Current size is 4.7 by 3.1 inches, but I expect that to increase somewhat.Unless we're suddenly crossing a major size/cost threshold I'd prefer to keep the headers, however I'm not opposed to the alternatives.
No worries!And if anything that I said led anyone to think that I thought ill of anyone, well you heard/thought wrong. I'm just congenitally frugal; it's in my blood-n-bone.
paul
