I'm going to start working through the circuit, but if anyone has an idea, I've got a really weird one (well, to me).
One drive works fine, and speed is correct. Works, boots, formats, etc.
The other drive:
When a double sided disk is in, which was what I had when I did drive 0, the speed test just hangs, but when I adjust the RPM it starts to report at 380. The lights on the drive board (Honestly I don't know what one means, unless its double sided detect, stop blinking as well once it falls below this speed. The other looks like an index indicator. When using a single sided disk, it works fine at 360 RPM.
I was thinking it was an index sensor, but since on double sided it works at 380 (reports), and on single it reports 360 (different index sensors I know).
I tested voltage out of the regulator and its giving 12 volt like it should. I'm going to study the schematics and the manual and see if I can determine if there is a logic chip that is bad.
Just curious if someone else might have seen this before. Trashing the logic board just seems wrong. Its also throwing drive not ready errors, but not always.
The other drive:
