phil.bischof
- Joined
- Feb 10, 2020
- Messages
- 54
I have a Tandy 1000 SX, and I am having a very, very hard time getting any of the old hard drives that I have working. I have a Seagate ST-238, and a Miniscribe 3438 P. Both are RLL hard drives. I am using a Western Digital WD1002A-27X as the controller card. I don't believe this has anything to do with Tandy specifically, but just posting it here since it's related and the knowledge base here is fantastic.
The ST-238 spins up, performs the low level format using the built-in (debug -G=C800:5) that the controller provides, and also completes a Standard Init in SpeedStor. However, after everything finishes, SpeedStor says it can't access the drive partition table and the drive is unusable. FDISK does the same thing, but with a more generic error message.
At first, the Miniscribe stepper motor was completely stuck, but after manually working it back and forth and lubricating it, it started working well. Then the diag light was flashing the code for Zero Track Interrupt Misadjusted, so I stepped through that process and got it back in line. It now LLF properly, and also does the Standard Init in SpeedStor, but it reports like 55 bad cylinders. After marking the bad sectors though, the partition fails with the same issue - "Unable to access drive partition table - drive unusable".
I desperately want to get one of these working. Can anyone give me any advice? I am not opposed to opening them up and checking internals, and I have a scope so I can check things on that level as well. I'm just lost and don't know what to try next.
If there is any other info that would be helpful, let me know and I will post.
Thanks guys!!!
Thanks guys!!!
