Everything was working, then I tried a cable that was larger that had the twist in it. I don't know if that caused the issue, but I untwisted the cable. Now I'm back to testing with the original cable. I have a single Teac drive and its motor no longer runs. I monitored the signal on the control board that tells it to turn on the motor and it does not change from .067V when I try to activate the drive. Does the Tandy 1000 use the motor signal? Or another signal to turn on the motor? Also, where on the motherboard is the FDC chip? I figured it would be near the FDC port, but in the pictures I've seen none of them say the number that is in the technical manual.
