I have a tandy 1000EX memory expansion board (25-1062) that is causing memory errors. I've swapped the drams and I get the same behavior. I've even taken the RAM out and it still fails. The tandy works just fine without the card inserted. This card has worked in the past, but I've had it out of the machine for a while.
I'm guessing static fried something? If it's not the drams, what is it likely to be?
When I boot it up, I see something like this:
Memory Size = 384K
Written Read Base Offset
85A4 A5A4 2000 FFFE
0A5A 5A5A 5000 0000
Memory Size = 384K
85A4 A5A4 2000 FFFE
0A5A 5A5A 5000 0000
