jasa1063
I recently got a Tandy 286 Express accelerator and installed in my Tandy 1000 SX as posted in this thread:
Everything is working great after swapping out all them memory in Tandy 1000 SX, but I still had one issue. The computer would freeze using a 80287 math coprocessor. I tried two different 80287 chips and they both did the same thing. I changed the dip switch settings for a 5MHz 80287, but that did not help either. I finally installed 80287XL and that seems to almost totally fixed the issue except that CheckIt still locks up the Math Speed test. I have tried versions 1.1, 2.1 and 3.0 and get the same result. All other benchmarking and software that uses the a math coprocessor works normally. I have run CheckIt 3.0 with a 80287XL in my Tandy 1000 TX, TL/2 and TL/3 and those work just fine. Any ideas on why this maybe happening?
