Eudimorphodon
I'd definitely agree with not worrying about the drives yet and concentrate on getting the computer itself breathing; you're not going to be able to meaningfully do anything else without video output.
Tandon is cast as part of the main body and there is a Texas Peripherals sticker on the bottom. Dated 1981Are your drives marked with a manufacturer's name?
-CH-
Next step, I swapped the floppy controller cards.
Something must have gone right, based on Ian's description it seems the machine is booting into TRSDOS.
Power on goes like this now:
Both drives start spinning,
Drive 0 lights up for a few seconds,
Drive 1 lights up for maybe a second,
there is a pause then Drive 0 lights up for a few seconds
then both drives stop turning
pressing D on the keyboard (directory? I have no idea!) results in a 2-3 second read of drive 0
This tells me that at least drive 0 is working properly (drive 1 has the controller card with missing components)
and also that the keyboard at least works for the letter D.
booting with the break key pressed did not change anything in the boot process so I suspect that key is probably not working.
Edit: I know I said video first then drives but this was too simple of a test to pass up and with seemingly good results I REGRET NOTHING!
While I am waiting on the first round of parts to arrive, I decided to look through the bag of 'stuff' that came with the computer.
I knew a bag of screws was in there but I have never actually looked at them or the included 100+ floppy disks.
As far as the disks, nothing of note, only 2 original disks in the entire bunch, mostly data.
There are a few ms-dos disks mixed in. Windows 3.0 on 5.25 and what seems like an entire copy (14 disks!) of Peachtree.
Regarding the screws I do have every small internal screw I need, but am completely missing the main case screws.
Has someone measured the stock hardware to make it possible to head down to the hardware store and pick up what I need? I believe it's 10 screws total for the Model 3/4 cases.
