Conmega
Ok... Where to start... Well I guess I can start with when and how I acquired it.
I got this laptop with its carrying bag and charger for Christmas from my grandfather about 4 years ago. He was moving into a new office at his work place and found it in the closet!!! He snatched it up knowing I loved old electronics and well electronics in general and gave it to me for Christmas! To be honest it was the most awesome present I had ever gotten! :mrgreen:
At the time I was 13 I think and well he hadn't done anything with it so I plugged it in noticing the battery being completely covered in corrosion took it out and just ran it off the power plug. It turned on and gave me this and still does give me this:
"Phoenix 80386 ROM BIOS PLUS Version 3.10.04
Copyright (C) 1985-1990 Technologies Ltd.
All Rights Reserved
640k Base Memory, 03072k Extended (this originally had lower extended ram but I bought two 1mb 30pin sticks to install)
Invalid configuration information - please run SETUP program
Diskette drive 0 seek failure (have the floppy drive out atm... trying to repair it...)
No book device available -
strike F1 to retry boot"
That's basically where I've been... for 4 years...
There is SOOO LITTLE info on this thing... Last night when searching for info again after a year or two of not touching it while it sat torn open waiting for me to fix it I found these forums...
Being 16 now and understanding it a little better I found some info about someone having one and knowing what it is!
I joined the forums and am now posting this for as much help as I can get with this!
I'd really love to see it running!
So now that all that is over I'll review the specs...
This laptop is a Tandy 3800 HD It has a Cyrix Cx486SLC as it's processor.
It has a 60MB Conner CP2064 hard drive in it.
It also has a EME-263MG floppy drive in it.
This laptop also has an Internal FAX/Modem Card (25-3532) installed.
I've installed two 1MB 30pin memory sticks in aswell.
Now to the dreadful part...
The problems...
Well to start... It appears the HD is dead... When in the laptop it spins up for a bit then stops... then spins up again... then stops... It doesn't appear to be seen at all by the laptop... I've made a adapter to adapt it to my desktop computer with standard IDE and I tested the adapter before hand with a different drive and double checked all my soldering so the adapter worked... But I put in the 60MB hard drive and got the same results as in the laptop... spun up and stopped... spun up and stopped... It wasn't seen by the bios or by windows... So obviously there is a problem with the HD... If it's dead or not I have no idea... I was hoping you guys could help with that!
Another problem is the floppy drive... I took it out tore it apart that two years ago and it needed a new belt... not finding anything suitable... that's when I left it to sit... I have now since found some suppliers for belts... BUT I already threw out the old belt years ago... so a belt spec or part number would be great!
I tried to temporarily fit a rubber band in there to test and see if it'd work... It spun up but it sounded like it was having trouble... like the band was too tight... but... I also noticed the heads didn't move at all... I'm hoping it doesn't move them if the drive doesn't get up to speed and thus they didn't move because i think it wasn't spinning fast enough... (Yes I made sure everything was connected to the driver board... as it should be...) But... If that's not the case then is my head driver motor is bad too? Also silly little problem... heh... I may have lost a few screws for the floppy drive... I should be able to take some screws form another laptop that will fit... But I wanted to make sure I am putting enough screws in and not too many... I'm pretty sure I'm missing three... two that hold the driver board down... and one that holds the back of the main driver motor down... If that makes sense... I can take pictures of all this later... Make a video if needed...
I've cleaned the battery out years ago also and forgot what type's of batteries and how many should be put back in the plastic shell of the battery!
So yea... Any help at all would be appreciated!
Also thanks to everyone who contributes to this forum considering its the ONLY place I've found info on this laptop other then radioshack's site...
here: http://support.radioshack.com/support_computer/1470.htm
and here: http://support.radioshack.com/produ...=Tandy Laptops and Portable Computers&Reuse=N
Don't quite know why there are two... but one does have some more info on it so...
Anyway thanks for any help anyone may give me!
All Rights Reserved
The problems...
