mloewen
Which adhesive works well for repairing cracks in a Tandy 6000HD shell?
No adhesive. Try MEK -- apply a thin film to each part and press together until set.
I've got lots of stuff that looks great after this treatment--it's nearly invisible, since you're dissolving the plastic that the object's made from.
Failing that, try cyanoacrylate.
Happy to hear it. I've occasionally also taken scrap and used a file to make some plastic dust, wet it with MEK and then spackled it into gaps where the original bits have been lost. With a bit of sanding, it looks fine--and the cracks don't reappear.
