did you shut it down? I can't log on anymore.
Around 3:30 in the morning .. it had been up for a week and we had some major thunderstorms coming in. I was copying down statistics while the lightning was illuminating the room.
Total uptime was around one week, 3 hours. In that time the machine sent 132067 TCP/IP packets and received 111346. 72 users registers and left around 70 messages.
The most visible bug was my retransmit timer. Due to a misconfiguration it was timing out on packets 10x faster than it should, so there were a lot more retransmitted packets than normal. This lead to some dropped connections - if a packet has to be retransmitted more than 6 times I assume the connection is dead.
There are some telnet options that I received and did not answer - I'm going to dig into those to see if that is something I should fix. There are also some warning from my TCP stack I'd like to look into deeper.
Overall, it was a great test. I think the machine is more than capable of handling a multi-user telnet BBS with reasonable responsiveness.
I'd like to thank everybody who signed in and poked around. I had connections from New Zealand, the UK, Canada, Brazil, and many points in the US. The oldest machine that connected was your Mac - most others seemed to be using Windows or Linux.
Mike
