Philcogrump said:
The twisted wires (red, orange and white) are for video and transmit/receive to the RS-232 port. I didn't really check what the ICs were when I had it opened up, but I think they all were normal TTL, but if these were RAM then it is likely.
I kinda thought the red or orange wires might be for video, I/O, etc. There are a couple of traces running from the J1 straight down to the wiring block where those wires originate, so the J1 probably just duplicates the same signals. The u12 - u18 chips are wired in parallel, like RAM chips would be.
I've searched online for information on anything related to MOSTEK, but not much luck (any reason why not?). By the way, this probably dates to the early 80s, if not, earlier so I'm wondering what kind of RS-232 data it uses? I tried interfacing this terminal with my laptop using Hyperterminal and never had any luck. I tried various settings, stop bits, etc etc without any success. BTW, there is a switch in the back of this terminal, and I think I read somewhere that some terminals gave the choice of half or full byte lengths or something?
I didn't have much luck either, except that the 3870 is code-compatible with the Fairchild F8 CPU, but a single-chip implementation, with either 2K or 4K of ROM (depending which webpage you read).
I think RS-232C has always been standardized. I've seen old boards that only use three wires; Tx, Rx, & Gd. The pins for Tx & Rx can be wired either of two different ways, but they should always be pins #2 & #3 on the 25-pin D-shell connector, with pin #7 used as ground. If you can't communicate with the terminal, try swapping pins 2 & 3, it should work one way or the other. I don't know about full or half bytes, but your terminal has to be in agreement with the computer as to word length, usually either 7 or 8 bits, and the number of stop bits, usually 1, 1.5, or 2. Full- or half-duplex settings determine whether the terminal or the remote system echoes the characters to your screen (easy to tell when this is set wrong, you'll be seeing double).
For the laptop communications, I'm wondering if the 5V source is too low for this to properly communicate with the laptop? Maybe I need some pull-up resistors (say 10K) to 12V? Any other ideas on how to make this useful?
Five volts should work, as the RS-232 interface usually has the pull-up already built-in (RS-232C uses 8v.). As for not communicating with HyperTerminal, why does that not surprize me?
--T
