oblivion
I just wanted to confirm this but does the Amiga 2000 only output monochrome via the rear composite jack? I wanted to do some simple video capturing via composite from my A2000 but all I was getting was a B/W signal. The Amiga is NTSC and not PAL. To firm this I even connected it up to a multi-format PVM with composite and still got a B/W image. After a quick google search I found some sources that indicate that the A2000 as well as the A1000 does indeed only output monochrome through its composite jack which strikes me as odd. I swear I remember capturing color footage from my A1000 through its composite jack. Is there something I'm doing wrong and need to enable to get color composite out? and if not what was the logic in only outputting B/W through composite when "lesser" computers like the C64 could do it.
