snuci
I need to retract the symptoms when I had the Nabu adapter hooked up. I removed a chip on the FDC card to check traces and forgot to put it back. Nabu adapter or not, it does the same thing. Sorry for the confusion.
Hi, I'm one of the original NABU game developers. I haven't caught up to the thread yet. However, I'm here just to let you know I'll be testing actual NABU CP/M release floppies for booting today. If I can get it booted, I can copy them for you. Wish me luck!
exciting, Good to have you on board!Hi, I'm one of the original NABU game developers. I haven't caught up to the thread yet. However, I'm here just to let you know I'll be testing actual NABU CP/M release floppies for booting today. If I can get it booted, I can copy them for you. Wish me luck!
Welcome aboard? Glad you are here.
It will be fun to see some of the source code on the games when you the discs archived. Curious - when you ported the games did you start from scratch or work with other versions of the code? (i.e. Coleco)
But the drives are shuggart right ? How can you use them unmodified on the PC ? Wasn't the hard setting for the head / side ?
One interesting test: try creating more than 32 files. See how the directory goes on BASIC NABU. Someone has reported the nabu images had weird 32 entries only.
Do these drives have a DS selection jumpers ? Still shuggart are different than PC driver this is the reason PC drives deal with twisted cables for drive / head selection. A good test would try to replicate your working BASIC disk to a second one using the PC. Also imaging the 41 entries disk would help with the geometry investigation.Sorry, I am moving this here from the Bad Image Thread because I want to keep that thread focussed.
The PC was set up for a 360k floppy drive in the BIOS. ImageDisk, when configured for single sided, did the rest. There was nothing special about the configuration other than ensuring the DS was set correctly and termination needed to be considered. The drives are TEC FB-50x drives. I don't have a picture of the exact model number. I do have the TEC manual though.
