Dr_V
I've recently acquired this old laptop that was already upgraded from its orriginal configuration and I'm upgrading it further. Just for fun, I fell in love with this little machine
Considering the its age, this laptop's performances are absolutely amazing! It runs Win2000 with resonable speed and Office applications very smoothly. I can even see a movie if it's not HD... :D
The current (upgraded) configuration is: 266Mhz Klammath (the CPU is built-in, can't be changed), 160Mb RAM, 40Gb HDD, 24x CD-Rom, FDD, video 2Mb (onboard, no chance to upgrade it), 100/1000Mbps PCMCA wireless LAN card, 4 ports external USB hub (because the laptop has only one USB port). The battery is brand new (factory refurbished), holds for almost 2 hours in full use (up to 3 hours in idle)!
The next move is a combo-drive or DVD-RW (I'm searching for a compatible model, it's not really hard to find).
I'm also searching for a compatible 3.5" card reader & USB combo to install in the FDD bay and an external touchpad or inverted mouse (the normal mouse needs a flat surface to work, it's unconfortable sometimes).
My only problem is the RAM. I can't go over 160Mb (32 internal +2x64) even with the latest BIOS update I could find
I'd like to install WinXP and below 256Mb will run too slow. Does anyone have some ideas how can I trick the BIOS to see 2x128Mb on the SODIMM bays?
