shawnerz
I'm so sorry I didn't see this earlier! I would have responded.Hey @shawnerz that's a great find it could potentially help fix all the other busted floppy drives from the T3200/SX/T5200 era - a real plague of failed FDDs.
Do you know the model of your drive? And what cap numbers (on the board) were they?
For example, I'm aware of 2 types of FDD in the T5200, a Toshiba ND-356S-A and a Citizen 0SDA-32C.
Cheers!
Keep in mind that I have the T3200, so my drives will be different.
I had 3 drives. I threw away the one I damaged beyond repair. Of the two, one is a ND-352S, and the other is a ND-356S-A. The ND-352S sometimes will read a disk correctly. It seems short reads are OK. But if you try to execute anything from disk, where there are sustained reads, it will fail.
I do not have a fix for this yet. I cam here to ask @Conventional Memories if he had a suggestion.
I hope that helps.
