So as part of the haul I made a little while I back I got several HDDs. None of them worked right off the bat, but thanks to Lorne I now have a copy of the 2.20 Advanced Diagnostics disk and was able to attempt to LLF all of them. Here are my results:
a) Drive: IMI 5012H (??mb)
Would not power up at all (no spin up or lights)
b) Drives: MiniScribe 6053-II (??mb) and Lapine LT 2000 (20mb)
Powered on and spun up but gave a 1701 error
c) Drives: Three WD-25 (20mb)
Original Problem: [LLF'd and partitioned just fine, but when attempting to
format in DOS they came back with a "Track 0 bad" error after about an hour
of activity]
Now: Two of these work perfectly after using the correct DIP switch settings. One still exhibits this error immediately upon attempting to format.
d) Drive: ST-412 (10mb)
Original Problem: [LLF'd and partitioned, then right as I attempted to format in DOS it
came back with a "seek error"]
Now: Works perfectly! Formatted and running DOS like a boss.
e) Drive: Maxtor XT-1140 (140mb)
Loud internal mechanism, LLF's fine, but does not DOS format
This is all running on a stock XT with the Xebec controller. Lorne has already said that these drives are probably toast, except maybe the last one.
Any suggestions? Or am I SOL? I'm willing to open these up if that's what it takes to get them going. :|
of activity]
