JDT
thank you ChannelManiac! This fine fellow sent me a v20 CPU for my 5150... I replaced the stock 8088 with it and BAM, I can read and write to the hard drive after booting from it!
So as someone had theorized, the T130B doesnt seem to like the 8088 cpu.. /shrug
oh happy days... i had been wrestling with that card for more than a year! weeeeee!
http://artofhacking.com/th99/c/S-T/20318.htm
the T130B is the only 8-bit scsi I have, actually i have 2 of them. I can use a SCSI hard disk if I disable the cards bios and load drivers from the boot floppy. However, I can not for the life of me get a SCSI hdd to boot. It either locks on bios init, or passes init (depending on which drive im fidling with) and locks when i try to format it.
The drives I have at my disposal are:
Quantum P80S - 80mb (locks system on access)
IBM (for apple) DSAS-3360 - 350mb
Quantum Fireball FB10S011 - 1.08gb (works with bios disabled, locks on bios init)
Seagate ST31230N - 1.06gb (bios enabled or disabled, never gets assigned a drive letter)
I've checked jumper settings for each drive. Parity enabled, I leave termination disabled as I have a terminator at the end of the chain, all drives assigned to SCSI ID 0,
Could it be the IO port or memory address settings from the card be the problem? I've tried various... is there one I SHOULD use? I admit I am not knowledgable about memory addresses.
any input appreciated. Thanks.
