Trident card that thinks Colour Monitor is Monochrome
s3freak
England
I am doing this thread in case someone Googles the above problem, where I have found workarounds.
Back in October 1994, we had our first 486 PC, with a Trident 9000i, and a 14” colour monitor that has all analogue control knobs (I am sure some of you will remember them). In October 1997, the monitor failed, so we replaced it with a LG StudioWorks 44i that has partly digital controls with analogue contrast and brightness knobs.
When we first booted, we found out that DOS was in black and white! (Windows was still in colour.)
What was happening was that on the VGA port, the “new” monitor used DDC for “detailed” monitor ID, rather than simple open and closed pins for colour, mono, etc. The DDC signals can fool the Trident card, intermittently causing the card to boot up in either colour or mono. You can recognise this when the TRIDENT sign on message during POST is either colour or mono.
We went through the Trident TVGAUTIL utilities and found the SMONITOR.EXE utility. When you run SMONITOR C, this reconfigures the current boot session so that DOS is in colour again. Likewise, SMONITOR M is for mono. We therefore added SMONITOR C to AUTOEXEC.BAT.
The limitation of the SMONITOR utility is that some games and apps still thinks that the monitor is still mono when in fact everything is back to colour. I remember FastTracker II warning that it requires a colour monitor and thinks you are still using mono, PC Check being in grayscale because it thinks that you have a mono monitor, etc.
In the more recent years when I revisited vintage computing, with much more technical knowledge, I built a replica of our first 486 PC. My Trident 8900D is still sometimes fooled by modern colour monitors, thinking that they are mono.
One of the other solutions, provided that the VGA cable is detachable, is to use a VGA cable that has does not have the monitor ID / DCC pins connected. However, I have not tested this extensively.
Another solution would be to configure and install the TVGACRTC driver, where you can control the TVGA card and monitor parameters, such as the size, position, refresh rate, colour and mono monitor, etc. Games and apps then also correctly identify the type of monitor. However, this is installing a device driver in DOS via CONFIG.SYS.
Now that I have some assembly programming experience, the SMONITOR utility only updates the grayscale summing bit in the BIOS data area, bit 7 at 0040:0089h, but not the type of monitor connected. I tried changing many commonly documented monitor type bits, such as 0040:0087h, but these had no effect.
After doing lots of debugging and seeing what bytes have changed in the BIOS data area, which turned out to be 0040:008Ah too, I wrote my own utilities, where you can “properly” change the monitor type in the current boot session. This will not only cause DOS to be in colour again, games and apps will also correctly detect the colour monitor. Furthermore, it keeps whatever text is already on the screen, so if you have a Logitech mouse driver message that is in grayscale, it would turn into colour, then everything will be as though the monitor is colour in the first place.
Unfortunately, I did not document my source code when I wrote it in 2019, but in general, it updates the BIOS data area to colour or mono, and calls a number of INT 10 functions to switch video modes whilst keeping the text. These scripts are written for the DOS debug utility, and may work with other cards too.
COLOR.COM
A
MOV DX,40
PUSH DS
MOV DS,DX
MOV AX,WORD PTR [89]
AND AX,F9F9
OR AX,0200
MOV WORD PTR [89],AX
POP DS
MOV AH,03
INT 10
MOV AX,0083
INT 10
MOV AH,02
INT 10
MOV AX,4C00
INT 21
R CX
25
N COLOR.COM
W
G
Q
MONO.COM
A
MOV DX,40
PUSH DS
MOV DS,DX
AND AX,F9F9
OR AX,0406
POP DS
MOV AH,03
INT 10
MOV AX,0087
INT 10
MOV AH,02
INT 10
MOV AX,4C00
INT 21
R CX
25
N MONO.COM
W
G
Q
I also attach the utilities, compiled with source in a .zip file.
Hope that this helps.
View attachment ColorMono.zip
I had exactly same problem with old 8bit ISA VGA and modern monitor. I added color.com to autoexec. It works. Thanks very much.
I also ran into a Trident video card getting confused and only displaying black and white. Usually it took a few resets to make it display color but eventually I replaced the monitor entirely with one less prone to making it start in black and white.
I recently experienced the same problem. With newly built vintage 486DX33 system using Trident TGUI9400CXI VLB VGA when hooked up to Dell Ultrascan D825HT CRT monitor (built Nov'97).
Your solution works. Thanks.
Just to confirm that it works perfectly on a Cirrus Logic CL-GD5401 (rebranded Acumos AVGA1, 256KB ram) on a vintage AMD 386 40dx, using a "modern" 17" (5:4) LG Flatron lcd.
Excellent work. Thank you.
WOW! I did exactly that - google the above problem and there you go - a solution that actually works like magic. Thanks a lot - not only for fixing it - but for posting it so that others can benefit.
In my case it is a 486dx33 retro build with a Trident TVGA8900C and an Iiyama CRT monitor. It would always start up either color, or monochrome, pretty randomly. Now problem solved.
I can confirm that COLOR.COM also works with an OTI-037C connected to an older 15" HP LCD.
I have a Trident TVGA8900 as well with same problem and i can confirm it works great! Thank you :)
/Mikkel from Denmark
Sorry if I was necroing this thread, but while COLOR.COM fixes color, it wrecks havoc in normal text mode. Typing CLS won't clear the screen anymore, but cause a blink on the screen. And running other text programs then exiting them will put garbage on the screen.
This is on a Trident TVGA 8900CL.
Welcome to the forum @wbahnassi!
It's not a necro-post, when the thread isn't even a year old, and you're adding useful information.
- Alex
Thanks Alex!
I looked at the VGA connector of my Trident TVGA 8900CL and noticed that of all the three VGA monitor ID pins, it just connects pin 12. Pins 11 and 15 are no-connect. Pin 12 goes directly into one of the legs of the main Trident chip.
So I went ahead and sucked the solder off the hole for VGA pin 12 to cut the connection, and the problem is fixed. The card now is consistently in color mode right from boot. It is possible to cut the connection at the chip's leg too.. it's up to you whether you prefer working with micro or regular size soldering. I prefer the pin 12 location because it's very easy to resolder again should the need rises.
I'm attaching photos of my card for anyone's reference. The close up image hopefully shows which pin to desolder. Make sure it's really cleaned from solder or else the connection may stay.
Another option if you don't want to touch the card or the cable is to add one of those "gender changer" adapters with the relevant pin removed.
For me color.com solved the problem in a slightly different scenario: a Cirrus Logic card started in color when connected to the monitor directly, but in mono when connected to a KVM + same monitor.
I ran into this issue with one of my newly built Cirrus GD-542x cards and can confirm that color.com fixes it for me, too.
While one of the cards with CL GD-5424 works just fine in color by default, a second board with GD-5429 lands in Greyscale mode. Curiously, Pin12 of the VGA connector is not even connected anywhere on the board (Design available on Github here).
Pins 11, 12, 4 and 15 on the VGA connector are "Monitor ID". The misdetection happens because the graphics chip misinterprets these signals with modern monitor. On the Cirrus chip, the "Monitor ID" pins are expected to be connected through pullups to pins 79 (P0), 82 (P1), 83 (P2) and 84 (P3) on the graphics chip, and grounded as needed inside the monitor.
As far as I can tell in the design, this is not implemented at all. The P0-P3 pins are only broken out to connector J1 and not connected to anything else. To always detect a high-resolution color configuration, you need to pull ID0 (J1 pin 1) and ID2 (J1 pin 5) to ground, and ID1 (J1 pin 3) to Vcc.
Semi-related: COLOR.COM pokes the BDA area directly. The Cirrus Logic Video BIOS also supports INT 10h / func 1Ah / subfunc 01h to set the DCC value programmatically.
Thanks for the heads-up. Frankly, I've never bothered with the classic monitor ID pins. I got my first PC plus Monitor in the mid 90s where monochrome monitor types weren't relevant anymore.
Yes, that's true for this particular design. Maybe the author disregarded p.348 of the Technical Reference Manual or just didn't bother. That being said, I am grateful for the work he has spent on this as well as his sharing on Github. I've incorporated the P0-P3 into my fork (including default pull-ups and the option to choose Monitor-supplied or static ID by jumper blocks).
Yep. Regardless, the particular chip I am seeing shades of gray with (no pun intended) still doesn't cooperate after pulling the 3 pins.
Strictly speaking, yes. On the other hand, the ability to poke things easily can also be seen as quite harmless source of fun in retro computing.
Thanks a lot!
confirmed working on a Samsumg Deskmaster 286 with a Cirrus Logic GD5429 ISA. (I was using the same card on a olivetti m250 286 but didn't have this issue)
As I know, there are 3 ways to detect monitor type:
1) IBM VGA doesn't have any ID pins. Monitor is detected via using output voltage comparer. Several color patterns are sent to monitor via reprogramming DAC color 0. Voltage changes, if certain pin isn't connected. Only one pin is available in mono monitor, so it has special reaction to color patterns.
2) ID pins.
3) DDC.
As detection is performed during POST only and then result is stored in BIOS data area, it's actually easy to trick video card into thinking that different monitor is connected via changing BIOS data.
Please remember, that there is difference between "mono moniotor" and "mono mode". Mono monitor means using special mono palette. So called "grayscale summing". It's done by BIOS in transparent way. "Mono mode" is used if other video card is present and it's CGA. List of video modes is limited to mono modes only in this case. Monitor itself doesn't have to be mono.
