Glen M
My mac classic analogue board I'm fairly sure now is beyond repair, certainly beyond my knowledge so for one last go I'm hoping someone out there will be able to help.
This started a while back when I purchased a mac classic locally for £30, talk about to good to be true! It needed recapped and I was happy to do that but when powered up with all new caps it gave a wobbly checker board. After some discussion that turned out to most likely be caused by electrolytic still on the board causing shorts. I took the decision to remove all components so I could properly wash the board. Its all through hole and single sided (obviously) so easy enough to do. All components were removed, labelled and stored for reuse except diodes DP5, 6, 7 that were crusty so got replaced along with IP1 and QP1. I tested all components I could before reinstalling and all checked out fine.
The board got a soak in soapy water then a bath in IPA to try and remove all the leaky gunk. It was thoroughly dried before reassembly.
Now however when powered up the fuse goes instantly with a bright light so must be some serious current running through it. Power supplies aren't really my thing and I'm starting to think removing all the components was a bad idea (all be it I got plenty of soldering practise!) Worth noting there is no obvious sign of damage to any other components.
To be honest I've more or less given up on it now but if anyone has any wild ideas as to whats happening please let me know. Failing that does anyone in the UK fancy taking a look at it? I'll warn you though the underside of it isn't pretty. The damage from leaked electrolytic was extensive and unfortunately various pads and traces lifted on me while desoldering. About 10 in total and all around the power section of the board. I've repaired it as best I can but I openly admit part of the cause was more than likely me being to heavy handed with the heat on the desoldering station.
Its a real shame as I had hoped this would be a cheap project box, just a recap and it would be fine. Never seems to work out that way.
Sorry for the long winded post!
