30) Is it possible to get 'online' with a Model 2000?
Yes, though only for calling a BBS or accessing the Internet through a
UNIX shell account. There is no software for making a TCP/IP connection
directly. A good terminal program, which also doubles as a BBS host, is
called GT-Power. It's quite a powerful package and utilizes a FOSSIL driver
to access the Model 2000's serial port, so the standard IBM version could be
used as long as you're able to find the correct FOSSIL for the Model 2000.
There was an excellent BBS run out of Andrews AFB in Washington D.C. around
1987, called TandyDC, and it was run on a Model 2000 and GT-Power. It must
be noted that there were two varieties of GT-Power produced, one which wrote
directly to the serial port of an IBM-compatible and doesn't require the
FOSSIL driver, and the version that used the FOSSIL driver to access the
serial ports. The Model 2000 can only use the FOSSIL version.
The main choice for running a BBS host on a Model 2000 is GT-Power. Due
to thier usage of a FOSSIL driver though it may be possible to get either
FIDO or OPUS to run on the Model 2000 as well. It should be noted though
that at this stage the versions being referred to are upwards of 10 years
old and may no longer be supported or no longer available online.
32) Can I run Microsoft Windows on the Model 2000?
The only version of Windows that will run on the Model 2000 is Windows
version 1. It requires a special driver disk, sold by Tandy under part#
7002611. It supported the Model 2000's high resolution graphics as well as
the Digi-mouse. Programs written to run under Windows 1 were then usable on
the Model 2000, such as Pagemaker 1.
