jaquinn
I did a test with Montezuma Micro CP/M 2.2 (Bios 2.30) on my Model 4 with the hard disk emulator. I used the HDRS15M driver and had no problems mounting a drive, formatting it, using PIP to copy files on and then executing programs from it. I didn't do efficient partitioning at all.... just used
HDRS15M F=AB H=C
But given that the RS drivers had no trouble with the emulator board I wouldn't expect any problems.
All the TRS-80 emulators that I am aware of use the same virtual hard disk file format.
If you want to make your drive file available I am happy to run it up to confirm that it works OK. Alternatively suggest a partitioning scheme and RS driver to use (I only have RSHD5M and RSHD15M... not sure if there are others) and I can try that.
I don't have a Model 4 so cannot test if a 4p would actually boot CP/M from the drive.
Regards
Andrew
HDRS15M F=AB H=C
Regards
Andrew
