Little help please.
I recently got a model I system unit fixed and am now moving on to
an unknown EI and drive set.
This is the first time I've ever worked with a TRS-80 EI and drives.
I've looked over the documentation and service manuals
So here's what I have:
An early version expansion unit with an active type cable and two drives.
I've used deoxit on the EI and drive cables.
The system unit seems to be connected as print peek(16561)+peek(16562)*256 shows 64K
whereas w/out the EI that yields 32K. Voltages look right in the EI.
Where I'm stuck is the drives. I have the terminated drive in the 0th connector.
The first two connectors are missing the orientation key but I oriented the connector
onto the drive as if it was there; at the bottom matching the notch on the drive edge connector.
When I power up the system unit I get a drive spin up about 1 in 5 times but only an
access LED light up about 1 in 10 times. Further, it never seems to never actually read the floppy as
the system immediately goes to the BASIC prompt. I have the drive all apart and can probe
everything. The rails look good; the drive head seems to be able to move freely/correctly.
It was very clean.
I have worked/reseated the connectors many times. Perhaps the edge card connectors at
all cables still need more work? Does this seem like a cable/connector issue?
I could move the terminator to the '61 drive and try that drive alone for booting unless
someone can offer other troubleshooting procedures.
I know someone here has been through this... right?
Thanks!
It was very clean.
Thanks!
