TRS-Pic - A Google Images viewer for your TRS-80
pski
Moderator
Staff member
New York
TRS-Pic. Coming soon for your MISE equipped TRS-80 Model I or your M3SE equipped TRS-80 Model III or 4.
Supports both 128x48 standard TRS-80 resolution or 640x240 hi-resolution with an optional Hi-Res graphics card.
Cool. BTW, easy to auto-detect the hires board if you want to make a single executable. I've got code that can determine Tandy/Grafyx/Grafyx Clone.
What's the architecture? I'm guessing the Z-80 asks the MISE to make a TCP/IP connection to a AWS instance that talks to Google Images and does the image conversion? Or does the Z-80 do TCP/IP itself?
Yes, it's pretty simple to check but I wanted to give the hires owner a chance to see the lowres images too so they could appreciate their investment. I could also add a switch that allows the user to toggle lo/hi res in the app itself.
btw, this is built using zmac! :)
Correct
I'll probably add serial port support too for use with a serial-IP converter.
That's reasonable. Might be an idea to have the hires version print a warning if no hires found. And, conversely, the lores version could mention that hires is an option. Though given the user base there may not be much point to rounding off the edges.
Nice! All the best software is :)
Very cool! Tried it and it works well. Now to find a high-res board for my model 4.
Great fun! lol
My 4P screen is a little narrow, don't you think?
Mike
I like it. Makes me 10lbs lighter!
Seriously though, is your display squishing the video or is trs-pic squishing the image?
The picture? Really? I'd say it's more the shave, the haircut, and ditching the hat. :D
My 4P has a tall, narrow picture (after adjustment). As soon as I can get a clear spot on my work table, I'll start a thread about it.
Now, back to our regularly scheduled TRS-Pic thread.
Mike
